Route diverted where road is all clear between waypoints
Creating local route for practice I found MyRoute made a lengthy diversion between  waypoints only 50metres apart on a clear road.  How does one override this? I am sorry if this is a typical beginer's question but I have looked for an answer. Thank you.
Pierregeorges
1 person likes this idea
Probably it is a 'closed road'.
Maybe a mountain pass.
See here the solution: http://us4.campaign-archive2.com/?u=16269e58d3ead51bbd54b69f8&id=9dd2666c9c&e=%5BUNIQID%5D
Thank you Michel.  Although the road in question is a two-way traffic road in a UK Midlands city centre the solution to the problem worked fine.  Thank you
Peirregeorges
Great! Maby a bug in the map, the solution is take an another map.
