Breadcrumbs not complete/correct with route file open
 The breadcrumb links work correctly when file lists are open, however once you open a route, the only breadcrumb shown is the root directory.  If the open file/route is contained in a subfolder (root -> subfolder -> routename) the only thing displayed is root -> filename.  This makes the user go all the way back to the root directory instead of simply clicking on the subfolder.
When working with multiple routes and creating new routes from existing ones, it's bothersome to have to always return to the root directory, then proceed through the different levels of subfolders.
1 Comment
