Library Issue
I was drilling down on a ride map cluster of 6 maps (dark circle with a "6" in it) and found that I could not see any of the individual maps, like I can for most such clusters.  I suspect that whatever criteria is used to place an icon on the map (starting point?) is the same for all 6, whereas most clusters have some distance on the map between ride icons if you drill down close enough.  Unless I'm missing something, there needs to be a way to select the individual maps when they are stacked like this.
1 Comment
