Google Maps search results missing
When I use Google Maps (stand alone, outside of MyRoute App), I get all the results I search for perfectly well, however, when creating a route and adding waypoints in MyRoute App web/iOS, I often get no results for a search. This is terribly inconvenient because I then need to zoom in where I know the waypoint is, see the result I want, and manually click it. Why don't Google Maps search results work as expected?
Here an example:
haliburton highlands brewing
1 person has this question
Good Afternoon BartmanEH,
Recently we changed the search algoritmes it should be back upto speed now.
Sometimes you need to zoom in a bit before filling in the adress.
Sorry for the inconvience and delayed response!
Kind Regards,
Customer Support Myroute-app.
I found the same issue today when searching for a business called Getgeared in Leatherhead. The seach facility on the map just doesn't give you the results you expect.  When creating a new route and starting with a map of the world, the search facility doesn't work at all.
