'Route Calculation Failed'
1: 'Route Calculation Failed' message seen if there is no phone signal,.I don't see why this should be so, the point of having downloaded maps is so it will work offline!
2: the 'Route Calculation Failed' message should give more detail;there are presumably multiple possible reasons for this failure, the user needs some clue as to what needs to be changed to have a chance of success.
Good Afternoon Gwallter,
The route calculation failed message probably has something to do with a road being closed but there still being a waypoint placed on it.
Have you made the route with the Garmin map on MyRoute-app?
2. I agree, I have added this suggestion to the list of the developers.
Kind Regards,
Customer Support MyRoute-app
The route was planned on MyRoute-app and had been fine an hour earlier, the bike was parked in a phone dead spot so when calculation failed I moved (about 100m) to a good signal spot and the route calculation succeeded. I gather from your question that you do not expect the absence of phone signal to cause a problem. ----
I have just replicated the problem at home by screening the phone (airplane mode gives the same results):
1: reloading last route - no problem
2: reloading previous route - calculation fails
3: loading any other route - "An error occured while connecting with the server" as you would expect.
This highlights the need for:
1: more detail in the error message.
2: the ability to select some routes to be stored locally
