Route distance variation
New to myrouteapp, but really liking what i've seen so far, the problem I have is that I created a route on myrouteapp which was 2800 miles, when I exported it to my Garmin (I switched recalculate off) the route then goes down to 2200 miles. Does anyone know the reason for this?
1 Comment
Unfortunately there isnt a lot we can do about this.
The problem occurs when the Garmin uses all of the trackpoints.
A simple solution for this is splitting the route into 2 smaller parts.
You can do this by clicking on 'toolkit' >  'split' > click on the routepoint you want the route to split at.
This will create 2 new routes. You will keep the original route, but now there will be a route from start to the selected routepoint and from the selected routepoint to the end.
I hope you found this helpful!
I will now close the forumpost to prevent other users from commenting on the forumpost with questions or suggestions not related to the original message.
Kind Regards,
Customer Support MyRoute-app.
