Answered
Following a route (Navigation)
I created a route on the website and not sure if this feature is in the works to be done, but it would be cool when out and about to select a route on the iPhone and have that either navigate me (inside the MyRoute-App) or open Apple or google maps, or as I have TomTom installed on the phone to navigate with that.
I do not mean using the connector to install a route on a navigation device, as I do not own any devices apart from TomTom on my iPhone, and the connector will not connect to that on OS X.
This is a question I am being asked a lot by my friends.
As a work around I did use the already designed route and track around that, however a few things had to be done and was noticed,
1, the phone lock screen to be disabled
2, the map did not rotate so it was hard to know which way to turn as it was upside down.
3, It created a new track of the route that was designed
Best Answer
The connection with Sygic (iOS/android) and Navigon (iOS is ready!
Other apps do not support the import of waypoints.
See a little instruction: https://youtu.be/mHk86D6MQAw?list=PLoRUfcAhS6_2WVEm-9jKbPxLKFxisEolu
is there a way to navigate a route on my android smartphone.
There is a way to export a route to Google Maps app on your smartphone, but you also have to use the pc TYRE program as well and it also only works if you have less than 10 route points (start, 8 intermediate and end).
1. Save the route from My Route App locally to your PC as any format e.g. .gpx.
2. Now open this file in TYRE on your pc.
3. On the menu go and select View....., Show Route (Google Maps)........ This opens in your browser.
4. If you have set up your chrome browser to log on to your Google account you get the option below the 10 max route points to "send this to your phone" click this.
5. Then on your phone open the route in Google maps and go ride
I try to use the connection between MyRoute-app and Sygic on my iPhone. It works fine if my route starts where I'm currently.
But I wanted to prepare my route in advance for a trip in the USA. So what I do in MyRoute-app on the iPhone: select the route, then click on the navigation symbol, select Sygic. Sygic open and says that some maps are missing. When I look the details I see that all my waypoints are correctly imported in Sygic but the start is my current position (which is really not near my planned route, therefore some maps are missing, see attached screenshot).
The waypoint added at the start is a point which can't be deleted so I'm not able to import my routes. It even sometimes crash Sygic.
Can I use MyRoute-app with Sygic to import planned trips which are not near my actual position?
(206 KB)
Any route made in MyRoute-app can also be transfered to your Garmin without effort Paolo :)
And we plan to have a free mobile navigation app released for MRA users in the coming months.
1 person likes this
Any news in getting the app to work with a free program like Waze ??
I bought the Gold version maybe a year ago and I found out I never used since I have a  a Navigator V ( made by Garmin for BMW ) and I can create a route on tyretotravel and send them oto Garmin - I would have bought the Navigon app and use it on the iphone but in my area the app has only 2 out of 5 star so I stick with using tyretotravel and Garmin.
You can upload routes in MyRoute-app through Routelab > Routeupload
Hi Paul, you can't import routes into MyRouteApp only export, but you as a Gold member you can use the TomTom map on the MyRouteApp in the browser to plan a route that, from the iPhone myRouteApp, select that route and send it to Sygic or Navigon for navigation, I use it all the time.
Hi Paul, once Gold you, basically use the TomTom map in the RouteLab in your browser (not on the iPhone) instead of the Google map to design your route, make sure you have up to 47 way points or 23 for Navigon, Gold lets you "Expand" (thats under toolkit) your waypoints after creating the route to a maximum you define, then on your iPhone, go into Start, select a route under MyRoutes/History, hit the pointy/funny/arrow/location icon at the top toolbar to send the route to Sygic or Navigon, ( I have both installed), don't forget to start tracking your run ;-)
Hope that makes sense
So you are saying use the TomTom export to load into my Sygic GPS on iphone?  If that works I will get a Gold upgrade.  Look forward to your reply.  Thank you.
 I like what you have done with your app!  Thanks.  Would like to upgrade to Gold so that I can use with my Sygic App on my iphone.  Is this as simple as using with my Garmin?  IF so, I will gladly pay for the Gold.  Do I understand correct taht I can use the TomTom conversion for Sygic as well?  Better perhaps?  Can you confirm that I do need the Gold to download routes from your app to my Sygic.
Thank you again.
No problem.
It is important to use 47 routepoints.
Because Sygic calculate between the routepoints.
Use the TomTom, because Sygic use the TomTom map too.
Place the routepoints correct.
I have a route in myroute web account. When I navigate through Sygic, this app (sygic) change the route. How can i navigate exactly my route?
Sorry, I need to improve my english
No thanks, feel free to give your feedback :)
Ah, yes I see now, I had the app on the iPad but using it via the website I can indeed edit my routes on my iPad.  Thanks
