Answered
Option to undo portion of route
I had a route that was S shaped. When I did anything to it, click Avoid Highways (even though there were none), added a way point to this route, etc, it would change the S to a B, closing the upper and lower parts as loops. I wanted to remove the portion of highway it added that did this, but there is no way to do so.
Is there?
Thanks!
Best Answer
Maby my English is not good enough, but I am not understanding what your mean. Can you explain a little bit more?
Answer
This is the original gpx file.
This is after I simply added my home waypoint at the bottom (off the page). See what it did to the original route at the top of the map?
