Export Function Failure When Route Name Already Exists
The export function via the connector will fail if the same route name already exists on the GPS.
I was only able to work this out when I'd made some changes to an existing route and then tried to export this to my GPS as the connector simply tells me that my unit is not connected (which it is.)
Deleting the route from the GPS itself then re-exporting the modified route from the connector works.
Okay, thanks for telling, we take a look at it!
