1. Open a route from your profile, our create a new route
  1. Click on "Routes" to start.
  2. Click on "Add" to search for the route to be added.
    A list will then appear of the routes that are within your profile. So you can only compare routes when they are on your profile.
1. Select a route that you want to compare with your current route
The second route will now be visible on your first route. Note: you can display more than 2 routes at the same time if you wish!
  1. The added route in red.
  2. You can adjust the color of your additional routes by clicking on the colored box below the route name and selecting a different color
  3. Click here to remove the route from the map.
  4. By clicking here you can add the route directly to your current route. You can add the selected route in two ways
    1. In front
    2. At the back
  5. Click here to add another route.
In this example I choose blue as an alternative color for the route
