In advance
POI's (Points Of Interest) are useful landmarks on your map such as: gas stations, hotels, restaurants etc. You can easily add POI's directly to your map by accessing our vast POI database system.
Some remarks:
-POIs are only loaded if you do not move the map.
-The more you zoom in, the faster the POIs load.
Steps for adding POI's to your route:
1. Open your route, and select 'Search POI's' on the left of your screen
A = Search POI's
B = Zoom map to load POI's, meaning that POI's will only appear when you've zoomed in far enough for them to load. After you've zoomed in enough, this emblem will change to the color green with the text "Select POI's"
C = The POI category menu. Select which type of POI you're looking for by selecting any category
2. Select the type of POI's you wish to add and zoom in far enough for them to appear. Note that it might take the map a few seconds to load all the POI's in compacter area's. If you're not certain whether or not you're zoomed in far enough to view POI's, look to see if the your emblem has changed to green with the 'Select POI's' text.
3.Select a desired POI and click on '+add'
*Toevoegen = Add
4. The following window will pop-up
Select a name for your POI, and then check the 'POI' box to add the point as an actual POI to your route. This wil make it so that your navigation device will recognize this point to be an actual POI.
This POI (and any other POI you add), will be located inside of the 'Manage POI's' tab on the left of your screen. This is also where, at any time, you can remove a POI from your map.
