At this moment we are still busy creating an import function for MyRoute-app Navigation.
As long as this is not ready, importing a GPX needs be done with a workaround.
You can log in with the same account credentials on MyRoute-app Web (www.myrouteapp.com) as you use for the navigation app. Once logged in on www.myrouteapp.com, you will find the button "import" In "Routelab".
A GPX file can contain routes and/or tracks. Depending on what your file contains and what wish to import, you can follow the steps below:
Route:
  1. Import the GPX as route.
  2. Check the route for errors.
  3. Reload MyRoute-app Navigation.
  4. The route will appear in your route list.
Track:
  1. Import the GPX as route-track.
  2. Select "use as route" to convert the route-track to an editable route.
  3. Check the route for errors.
  4. Reload MyRoute-app Navigation
  5. The route will appear in your route list.
