The MyRoute-app route editor is also an excellent platform for cyclists to create their routes. Follow the steps below to create a perfectly mapped out route!
- Create a new route (enter the name and set privacy settings as desired). Select 'cycling' as transport mode.
- We recommend using the OpenStreetMap as the basic map; this map has the most information about the different cycle paths.
- You can add waypoints on the different roads as you wish and create the route!
- Tip! Especially for planning cycle routes, we have included the OpenCycleMap map layer in our route planner. This is very useful when planning cycle routes because it shows different cycle junctions. The different map layers can be found under the icon in the top right corner of the route planner. For more information about the different map layers, see the Manual 'Map Layers'.
