MyRoute-app makes it possible to embed your personal library of routes and tracklogs on your own website. It is also possible to embed a single route. Embedding can be done in different ways and this will be explained in the text below.
First, this is important!
For other people to see your route, it is important that the privacy settings are set to 'public'. Secondly, it is very important that your routes are published. You can do this as follows:
- Open the desired route in the Routelab;
- Select 'Route information' in the left-hand column;
- Click on 'Publish route'.
- Your route is now published in your personal routelab library. This can be seen by an orange tick and the text 'Route published'. You can simply undo the publication by clicking the same button again.
Enclose the entire personal library
Via the profile page
- Select 'Profile';
- Click on 'Embed';
- Use the obtained code on your website.
Via the Routelab
- Go to your personal route list (click on 'Routelab' and then on 'Routes');
- Click on 'Embed' in the right-hand corner;
- You will see an example of your library. Click on 'Get code' at the bottom;
Embedding a single route
Via Routelab
- Click on the icon with the three points to the right of the route you want;
- Select the 'Share' heading;
- Then click on 'Embed';
- You will then be given the option to select embedding width. After you have done this, click on 'Get code';
