With this functionality you can easily compare the route calculation of the different maps. This is the first step to making every route universal!
ATTENTION! This functionality is part of the Toolkit and requires the Routeplanner Gold subscription. See Which subscriptions does MyRoute-app have? for more information about our subscriptions.
The option to compare your route with the different maps is part of the Toolkits. For more information about the Toolkits, see Manual 'Toolkits'.
When you open the Toolkit, you will see 'Compare route with' under Route tools. If you hover over this option with your mouse, you will see which maps you can compare with. In the example, the route was created in the HERE map, so it can be compared with the OSM and TomTom maps.
Select the map(s) you want to compare with. A check mark will appear behind the map when it is selected for the comparison.
The original route will always be shown in black. The black line in this example is how the HERE map runs the route. The comparison was then made with both the OSM and the TomTom map. The TomTom map is the red line and the OSM map is the blue line.
This clearly shows that the three different maps all do something different at this point. By adding and adjusting waypoints it is possible to make the route the same on all three maps.
