With MyRoute-app you can easily and quickly create a beautiful roundtour with the generator. Read this manual to find out how the roundtour generator on the website works.
If you want to know how to create a scenic route with the generator, read Manual 'Scenic route generator'. If you want to know how the generator in the app works, read App - Routes & Tracks.
Table of contents
Start with the generator
When you log in to the website, you will immediately see the generator on the home page.
  1. Roundtour/route: Switch between creating a roundtour or a route here;
  2. Current location: If you click here and the website has access to your location, the current location will be filled in as the starting point;
  3. Favorites: Choose between your favorites to use as the starting point here;
  4. Address: Manually enter an address here to use as the starting point;
  5. Duration/distance: Switch between entering the duration or the distance here. With the distance you will see this slider;
  6. Surprise me: Let the generator create a roundtour based solely on your starting point and distance/duration;
  7. Next step: Click here to add some extra settings to your roundtour yourself.
Settings
This step is skipped completely if you have chosen Surprise me in the previous screen. Click on the image to view the details.
  1. Direction: Indicate here which direction the roundtour should go;
  2. General avoidances: Indicate here whether the roundtour generator should avoid at all;
  3. Avoid specific roads: Indicate here whether the roundtour generator should avoid certain types of roads;
  4. Previous step: Click here to go back to the previous step;
  5. Generate: Once you have filled in all the details, you can click here to generate the roundtour.
Result
If you have clicked on generate, you will see a loading screen. Here you can already give a name to this roundtour.
  1. Options: Here you can see the roundtour options that were found with your settings. There can be a maximum of 3;
  2. Start over: Click here to go back to the beginning and adjust settings;
  3. Use this roundtour: Satisfied with the result, click here to open the roundtour in the Routeplanner.
ATTENTION! The different options generally also give a different curvature. The first option is considered by our program to be the most fun option and therefore usually the most curvy. If there is a second or third option, these contain a different curvature factor.
However, whether a tour is fun or not is a subjective choice, so for this reason the choice of these options is entirely up to the user.
Save roundtour
The roundtour has now been added to your personal list as a route-track. If you want to make an adjustment to this roundtour, click on + edit route-track (top right of the map).
You will now see a pop-up where you can change the name of the roundtour. By editing the roundtour, you turn it into a route and waypoints are added. Check the placed waypoints to avoid unpleasant surprises.
