Further to the idea about EV Charging
I own an EV and use this site a lot to plan my routes. I use it in conjunction with Zap-Map in the UK. There are different lists for each country that combine all the various charging networks and charging types/speeds. For the UK, Zap-Map is often regarded as the definitive list. The Zap-map app allows you to filter by charger type or network or speed. Try it out and you will see what I mean. Then the site "A Better Route Planner" has much of the details for other countries but I can't (as far as I remember) extract the map and use it in my SatNav like I do with the routes here. Perhaps you might like to get together with ABRP? https://abetterrouteplanner.com/
