POI display at lower zoom levels
There was a discussion concerning POIs not being displayed at zoom levels above 500 meters which was closed. I struggled with having POIs display at all until I saw this post. If you are interested in POIs that are typically not right adjacent to the highway this restriction is absolutely crippling. I have used MS Streets & Trips for years and that was probably the best routing app to date. The way it solved the problem of too many POI icons close together was to display the appropriate icon with a number embedded to indicate a group. I have mostly used routing apps to plan RV trips and not being able to see applicable POIs that are off the highway up to a couple miles makes that kind of planning nearly impossible.
