The app can be used with many Bluetooth controllers. Each controller has its own working method. Therefore, read in this manual how you can use the MRA app with your controller.
TIP! Use the table of contents to quickly access the information you require.
Table of contents
- General information
- BarButtons
- WunderLINQ
- SilverFox
- Carpe Iter Adventure Control
- Carpe Iter BMW Control
- Carpe Iter (oud)
- Remotek One
General information
All Bluetooth controllers are actually Bluetooth keyboards. This means that all buttons pass a code as if you were clicking on a keyboard. This manual therefore explains for each controller what exactly the button on the controller does and which code corresponds to it.
Do you want to be able to test what the buttons on your Bluetooth controller do? Use this handy link to see which code corresponds to which button.
BarButtons
What is BarButtons?
BarButtons is a robust controller to operate the app on your motorcycle. The no-nonsense mentality makes it an affordable option where you can choose the ready-made option or a DIY kit.
Controls
Menu
BUTTON | ACTION | CODE | FUNCTION |
3 | Short press | N | Cancel |
4 | Short press | C | Confirm |
Map home screen
6 | Press button | Arrow up | Move map up |
8 | Press button | Arrow down | Move map down |
5 | Press button | Left arrow | Move map to left |
7 | Press button | Right arrow | Move map to right |
1 | Press button | + or = | Zoom in |
2 | Press button | - | Zoom out |
3 | Short press | N | Open menu |
3 | Long press | D | Start navigation |
4 | Short press | C | Operate compass |
Navigation
3 | Long press | D | Skip waypoint |
WunderLINQ
What is WunderLINQ?
Thanks to the WunderLINQ it is possible to also use your BMW Wonderwheel for your phone. This way you can also operate the MRA navigation from your steering wheel without any problems.
Controls
Map home screen
Up | Arrow up | Zoom in |
Down | Arrow down | Zoom out |
Press to the left | Left arrow | Open menu |
Press to the right | Right arrow | Operate compass |
Long press to the left | Escape | Back to the previous app |
Long press to the right | Enter | Start navigation |
Navigation
Long press to the right | Enter | Skip waypoint |
SilverFox
What is SilverFox?
SilverFox is a Finnish company that makes controllers for the engine. The sleek design ensures that it is a nice visual addition to your motorcycle rather than a distraction
Controls![](https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/12147236696/original/W0spKm-w47xSYeNqw7GkIMgvHYkDq4J1xQ.png?1722496170)
Before you can start with the SilverFox and MyRoute-app, the SilverFox must be in the correct position. Use button 4 to switch between the profiles. For MyRoute-app you must have F1.
TIP! Do you want to zoom in and out but change the volume? Then you are in the wrong profile.
Check their website for more information about the profiles.
Menu
3 | Long press | B | Cancel |
2 | Long press | A | Confirm |
Map home screen
5 | Up | Arrow up | Move map up |
5 | Down | Arrow down | Move map down |
5 | To the left | Left arrow | Move map to left |
5 | To the right | Right arrow | Move map to right |
3 | Short press | + or = | Zoom in |
2 | Short press | - | Zoom out |
3 | Long press | B | Open menu |
1 | Long press | D | Start navigation |
1 | Short press | C | Operate compass |
Navigation
6 | Up | Arrow up | Move map up |
8 | Down | Arrow down | Move map down |
7 | To the right | Right arrow | Move map to right |
1 | Short press | + or = | Zoom in |
3 | Long press | N | Open menu |
2 | Long press | A | Change displayed arrival time (end, via or shaping) |
What is Carpe Iter Adventure Control?
The Carpe Iter Adventure Control is, as the name suggests, especially for the adventurous (but also touring) motorcyclist. The device has few buttons, but you can still control everything you need with it.
Controls
Menu
3 and 4 | Short press | A or Escape | Cancel |
2 | Short press | Enter | Confirm |
Map home screen
1 | Up | Arrow up | Move map up |
1 | Down | Arrow down | Move map down |
1 | To the left | Left arrow | Move map to left |
1 | To the right | Right arrow | Move map to right |
2 | Short press | Enter | Operate compass |
3 | Short press | A | Zoom in |
4 | Short press | Escape | Zoom out |
Navigation
What is Carpe Iter BWM Control?
This controller is especially for the GS rider. Together with the hub for your Wonderwheel and the separate controller, you can control everything from your handlebars to make a successful trip with the MRA app.
Controls
Menu
1 | Up | + or A | Previous menu item |
1 | Down | - or Escape | Next menu item |
5 | Short press | Arrow down | Cancel |
1 | To the right | Enter | Confirm |
Map home screen
1 | Up | + or A | Zoom in |
1 | Down | - or Escape | Zoom out |
5 | Short press | Arrow down | Open menu |
2 | Short press | Right arrow | Start navigation |
1 | To the right | Enter | Operate compass |
Navigation
2 | Short press | Right arrow | Skip waypoint |
4 | Short press | Arrow up | Route overview |
3 | Short press | Left arrow | Change displayed arrival time (end, via or shaping) |
Carpe Iter (oud)
What is Carpe Iter (oud)?
Carpe Iter previously also sold the CI Control. Although it is no longer made, MRA can also be used with this controller.
Controls
Menu
1 | Long press | D | Cancel |
3 | Short press | Escape | Cancel |
2 | Short press | A | Confirm |
1 | Short press | Enter | Confirm |
Map home screen
2 | Short press | A | Zoom in |
3 | Short press | Escape | Zoom out |
2 | Long press | B | Open menu |
1 | Short press | Enter | Operate compass |
Navigation
1 | Long press | D | Skip waypoint |
2 | Long press | C | Change displayed arrival time (end, via or shaping) |
Remotek One
What is Remotek One?
The Remotek One is made by a Norwegian company. Don't be fooled by the dimensions of this controller. Precisely because it is slightly smaller in size, it is fully compatible with the MRA app.
Controls
Before you start, it is important that you have set the correct profile. The Remotek One has several
profiles that you can switch between. For MyRoute-app you must select Map Profile.
- Click on button 1 twice in succession and hold the button down for 1 second the second time. You should now see the green light flash once.
If you experience problems with the device, you can also switch between the iOS and Android modes. In most cases, the Android mode seems to work best, even when you use an iPhone.
- Press and hold buttons 1 and 4 simultaneously for about 1 second. The light now flashes green for Android mode and red-green for iOS mode.
For more information, see the Remotek One manual itself.
Menu
6 | Click once | - | Cancel |
5 | Click once | = | Confirm |
Map home screen
1 | Click once | Arrow up | Move map up |
4 | Click once | Arrow down | Move map down |
2 | Click once | Left arrow | Move map to left |
3 | Click once | Right arrow | Move map to right |
5 | Click once | = | Zoom in |
6 | Click once | - | Zoom out |
1 | Click twice | K | Open menu |
3 | Click twice | M | Start navigation |
2 | Click twice | C or L | Operate compass |
Navigation
4 | Click twice | N | Change displayed arrival time (end, via or shaping) |
