You can find all your saved routes in the Route List. These can be routes that you have created yourself, uploaded, or copied from friends. You can use folders to structure this list and organize it as desired.
ATTENTION! This concerns the route list on the website. For more information about your route list in the MyRoute-app, view App - Routes & Tracks.
Open route list
You can open the route list in two ways. Firstly, you can click directly on Routes from Route Lab. The other option is via the bar that you see when you have opened your profile.
Overview
The image below shows what the route list looks like. Click on it to enlarge and to see the details better.
- Name: Below you see the names of the folders and routes.
- Type: See here whether it is a map or route
- Privacy: See here who is allowed to view the map/route.
- Changed: When was the route last changed? ATTENTION! This option is colored blue. This shows that the list is sorted by last modified date. Click another option to adjust the order.
- Distance: See the distance of the route here.
- Duration: See the duration of the route here.
- More options: There are some additional options available for folders and routes. Read in the next chapter what exactly is possible.
- Search: Click here to search your list by name.
- Embed: Click here to embed your route. This makes it possible to display your curated library on your own website. See How can I embed my route? for more information about this.
- New: Click here to add a new map or route to the list.
Options per route
Behind each map and route, you will see some extra buttons. These are the extra options for folders and routes.
- Lock route editing
- Copy route
- Edit map/route
- Delete folder/route
- More options
Lock route editing
Sometimes you want to be able to view a route without changing anything. By locking the route, editing is not possible. You can turn this off via the list, but also from the route itself.
Copy route
With MRA, changes in the Route Editor are automatically saved. Do you want to work on a route but are you not sure whether the changes will be successful? Then first make a copy of your route to keep the original.
Give the route a new name and choose the folder where the copy should be saved.
Edit map/route
From the route list, you can also quickly edit the properties of a folder/route.
- Change name: Change the name of the folder/route here.
- Privacy mode: Change the privacy mode of the map/route here.
- Departure date and time: Give your route a departure date and time. If the route already has a date and time, you can also delete or adjust it here. ATTENTION! This is not possible when editing a folder.
Delete folder/route
Click here to delete a folder/route.
More options - Folder
- Properties: Here you can see the properties of the folder and what adjustments you can make.
- Name: Change the name of the folder here.
- Privacy: Adjust the folder's privacy mode here.
- More actions: You can also move and delete a folder this way.
- Share: Click here to share the route via your desired channel.
More options - Route
Routes contain more options than folders. Click on the image to enlarge it and to see the details better.
- Start time: Adjust the date and time of the start here.
- Copy: Make a copy of your route.
- Move: Move this route to another folder.
- Delete: Delete the route.
- Save as: Save your route in the correct file format or email the route in the chosen file format.
- Export: Do you use your own navigation system? Click here to export the route. For more information, see manuals 'Installing the connector' manual - Windows & MacOS and 'Exporting with the connector' manual - Windows & MacOS.
Select folders/routes
Sometimes you want to select multiple folders/routes at once to move or delete. This is also possible in the Route List.
- Gray box: Move the mouse over the folders/routes and you will see a gray box appear. Click on this to select it.
- Checked: You have clicked the box and the folder/route is selected. If necessary, select several at the same time.
- Items selected: See here how many folders/routes you have selected.
- Move: Move the selected folders/routes.
- Save as: Save the selected folders/routes in the chosen file format
- Delete: Delete the selected folders/routes.
Add folders/routes
You can also add new folders and routes from the Route List. Click + New at the top right to open a dropdown menu. Here you can choose from a new folder, create a new route, or upload a new route.
