In this manual you can read how your beautiful MRA routes can be imported to your HD BoomBox GT infotainment system models between 2019-2023. If you have an older Boombox, read Harley-Davidson- Boombox. If you have a newer Boombox, read Harley-Davidson - Boombox Skyline-OS for the correct instructions.
Table of contents
Export from the Routeplanner
- Connect your USB stick to a computer;
- Go to the website on the computer and open the route you want to import into the Routeplanner;
- Click on 'Save as' and choose Harley Davidson Boom Box 2019;
- Go to your downloads on the computer and add the .GPX file to the USB stick.
Import to the HD BoomBox GT
- Start the BoomBox GT system and wait until the menu opens;
- Connect the USB stick to your Harley Davidson;
- Click on Nav and go to the menu (middle button);
- Click on search (top left);
- Swipe left on the screen to find the Importbutton. Click on this and select your USB stick
- Can't find your USB stick? First check whether it is properly connected. If it still doesn't work after this? Then use another USB stick that is formatted as FAT32.
- Now select the desired route to import;
- Select Route- to start route navigation;
- Now click on the button on the right between the arrows to start the import. You may be asked for confirmation. Answer this with YES;
- When the import is complete, go back if necessary to import multiple routes;
- After importing, you can safely remove the USB.
ATTENTION! If a route is longer than 500km, it may take longer to load. Don't click all the buttons, but wait patiently until the route is loaded.
Start navigation
- Open the menu and click on Nav;
- Swipe left on the screen to find the Rides button;
- Select the desired route you want to ride and click on Start;
- Wait until the BoomBox GT has loaded the route. You can see the progress on the top right;
- Click on Go and you are ready for the ride!
