With MyRoute-app you can easily and quickly create a beautiful route with the generator. Read this manual to find out how the scenic route generator works on the website.
If you want to know how to create a tour with the generator, read Manual 'Roundtour generator'. If you want to know how the generator works in the app, read App - Routes & Tracks.
Table of contents
Start with the generator
When you log in to the website, you will see the generator directly on the home page. It starts by default on the roundtour generator, so switch immediately to Create a scenic route.
- Roundtour/route: Switch between creating a roundtour or a route here;
- Current location: If you click here and the website has access to your location, the current location will be used;
- Favorites: Click here to choose a favorite;
- Start: Manually enter an address here to use as a starting point;
- Swap: Swap the start and end points here;
- End: Manually enter an address here to use as an end point;
- Surprise me: Let the generator create a scenic route based solely on your starting and end point;
- Next step: Click here to add some extra settings to your scenic route yourself.
Settings
This step is skipped completely if you have chosen Surprise me in the previous screen. Click on the image to view the details.
- General avoidances: Indicate here whether the route generator should avoid at all;
- Avoid specific roads: Indicate here whether the route generator should avoid certain types of roads;
- Previous step: Click here to go back to the previous step;
- Generate: Once you have filled in all the details, you can click here to generate the route.
Result
If you have clicked on generate, you will see a loading screen. Here you can already give a name to this route.
- Options: Here you can see the route options that were found with your settings. There can be a maximum of 3;
- Start over: Click here to go back to the beginning and adjust settings;
- Use this route: Satisfied with the result, click here to open the route in the Routeplanner.
ATTENTION! The different options also give a different curvature. The first option is considered by our program as the most fun option and is therefore generally the most curvy. The third option is usually the fastest route and will therefore contain a low curvature.
Save route
The route has now been added to your personal list as a route-track. If you want to make an adjustment to this route , click on + edit route-track (top right of the map).
You will now see a pop-up where you can still change the name of the route. By editing the scenic route, waypoints are added to recreate the track line. Check the placed waypoints to avoid unpleasant surprises with your route.
