MANUAL 7 OF 7
The MyRoute-app also lets you navigate and receive turn-by-turn directions. Read this last guide to learn how to navigate all your routes with our app.
ATTENTION! To use the navigation module in our app, you must have a Navigation Next subscription. This subscription can be purchased through the webshop on a monthly, annual, or lifetime basis.
Starting the navigation
Read the App - Routes & Tracklogs section for the steps you need to take before starting navigation. Starting routes, an AB route, and a scenic route are slightly different and will therefore be discussed separately in this explanation.
Route versus Track
The app offers two navigation options: route navigation and track navigation. The most important thing to know is that there are slight differences in features between these navigation styles. If you enable the 'Navigate routes as tracks' option, track navigation will also open with your routes.
Route
- Route name: See the route name here;
- Duration and distance: See the duration and distance here;
- Waypoints: See the list of waypoints here. Open the list to start from a specific waypoint;
- Route settings
- Start from nearest waypoint: Start the route from the nearest waypoint or not;
- Use current location: Start the route from your current location or not;
- Route optimization: Choose whether to use the fastest or shortest route.
- Avoidance options: Indicate which roads should be avoided during navigation.
- Start: Click here to start navigation.
- Edit: Click here to open the route in the Routeplanner.
AB route
- Destination: View your final destination.
- Duration and distance: View the duration and distance.
- Options: If the route has useful alternatives, they will be shown here.
- Route settings
Scenic route
When you start driving a scenic route, you will not see a different screen after setting the options. Navigation starts immediately when you click Navigate. For more information about scenic route settings, see App - Routes & Tracklogs.
Resume navigation
If navigation was accidentally closed, don't worry. This message will appear when you open the app, and you can easily restart navigation.
Navigation screen
For the navigation screen explanation, all options are checked. In the navigation settings, you can choose what you want to hide.
- Upcoming road: See the upcoming street name;
- Upcoming instruction: See the next instruction here;
- Lane instructions: See which lane to take, for example, at an exit;
- Upcoming waypoint: See which waypoint will be next. Click this button to skip this waypoint (only for routes, of course);
- Next instruction: See what the next instruction will be. If you have checked to show gas stations in the navigation settings, the nearest gas station will be shown here, if available;
- Add POI: If you have added POIs to the route in the Routeplanner, you will see them while navigating. Long-press the POI to add it to the route;
- Speed: See the speed limit and your current speed;
- Current street: See the name of the road you are currently on;
- Time and duration: See how much time remains. ATTENTION! Here you can choose between the end point, next formation point, or via point. The end point is shown by default. Click once to see the time and distance to the next formation point. Then click once more to see the time and distance to the next via point.
- Zoom in/out: Zooming will automatically occur, but click here to zoom in or out further. Want to return to the default setting? Click the compass.
- Tracking: Click here to start, pause, or stop the track. You can also view statistics and add a photo.
- Compass: By default, the camera is set to dynamic, meaning it's tilted and automatically zooms in and out. See App - Basics for more information about the different camera options;
- Open menu: Click here to open the menu.
Menu
This menu is visible during navigation. ATTENTION! Some options are not visible in certain navigation modes. This will be indicated accordingly.
- Close: Click here to close the menu;
- Settings: Open the navigation settings here;
- Map settings: Open the map settings directly here;
- Stop navigation: Click here to stop navigation;
- Lock screen: Click here to lock the navigation screen. To disable this option, click the lock icon on the navigation screen;
- Add stopover: Click here to add a stopover while navigation is already in progress. This can be either a POI or a custom address. ATTENTION! This option is not available for scenic routes;
- Voice instructions: Quickly turn your voice instructions on or off here;
- Audio warnings: Quickly turn your audio warnings on or off here;
- Waypoints: Click here to open the list of waypoints. ATTENTION! Only visible when navigating a route;
- Skip waypoint: Click here to skip the next waypoint. ATTENTION! Only visible when navigating a route;
- Show route: Click here to view the entire route;
- Favorite location: Click here to save your current location as a favorite.
ATTENTION! When driving a scenic route, you'll see the "Return to route" option. If you need to deviate from the route, click here to return at the nearest point.
Settings
We strive to meet everyone's needs with our app. That's why we offer many settings you can adjust to optimize your experience. This manual lists and explains all the settings, making it a long list. Everything is listed in the same order as in the app, so you'll know exactly where to look for a specific setting.
Functional
The settings below affect how navigation is calculated and how the route may be modified while driving.
- Offline navigation: Are you going to drive somewhere where you are not sure about your internet? Then turn on the offline navigation. ATTENTION! Before using this option, you must make the map of the region in question available offline.
- Skip waypoints automatically: The route cannot be followed completely and you cannot pass a route point, by enabling this option this route point will be skipped automatically. You will then see a pop-up message with which you can still cancel the skipping. If you do nothing, the route point will be skipped.
- Traffic-aware route calculation: If this option is on, you will see the delays on the map when starting the navigation. If there is a long delay, the arrival time will turn yellow. The app will also choose the fastest route during a recalculation.
- Search for fuel stations along route: Choose here whether you want to see fuel stations along the route. This way you can easily add one to your navigation.
- Check if routes were made in the HERE map: Choose whether or not to check if the route has been created in the HERE map or not. If the route is not created in the HERE map, differences may arise between the created route and the final route that will be navigated.
- Check for route violations: It may sometimes happen that your route contains a road that you are in principle not allowed to drive on, but the route still runs on this road due to circumstances (think of a placed waypoint on a road with a weight limit for trucks). With this setting, you will receive a warning when starting the navigation and while driving if your route contains such a road.
- Check track navigation for errors: With this option turned on, you will receive an informative message before the navigation starts with points that may cause problems. Click no if you are not interested in seeing these points and click yes to show the points on the map.
- Allow track navigation for routes: Select here if track navigation for routes is allowed or not. If this function is on, track navigation will always be started, regardless of whether it is a route or track.
- Automatically start tracklog for routes: If you enable this setting, the track will start automatically when you start driving. ATTENTION! This function only works while navigating routes.
Audio
While navigating it is possible to receive certain notifications. These can be switched on or off and adjusted in this menu.
- Volume: Adjust the volume of the voice instructions here. Play the audio sample to adjust the sound for notifications using the volume buttons.
- Voice: Adjust the voice of the instructions here.
- Voice prompts: Choose here whether or not you want to receive voice instructions. It is also possible to choose between fully spoken instructions or just a beep as a warning. To also hear descriptions of waypoints, you must select the 'On' option here.
- Audio delay: Do you notice that instructions are sometimes only partly spoken? If so, turn on the audio delay here and the app will wait longer before saying the instruction.
- Number of voice prompts per instruction: Indicate here how many instructions you want to receive with an instruction. You can choose from four options, namely:
- Receive the instruction once, only the action itself
e.g. turn right - Also, get a reminder of the distance to the action
e.g. turn right in 500m - Get an extra reminder of the action to be taken
e.g. turn right after 2km - Get the furthest possible notice of the action to be taken
e.g. turn right after 5km
ATTENTION! Regardless of the instruction for the action, the other messages are not always guaranteed. Sometimes these do not exist.
- Waypoint notifications: Choose whether you want to receive a notification when you are almost at a waypoint. It is also possible to choose between all waypoints or just the waypoints.
- Speed warnings: Prefer to get a warning if you're speeding? Choose here to turn it on or off or only receive a warning if there is a known speed camera.
Screen layout
Everyone has different wishes for the navigation screen. Choose what you do or don't want to have on the screen by default with these settings and see what works or doesn't work for you!
- Current road: See the name of the road you are currently driving on the screen.
- Upcoming waypoint: See which waypoint will be next. ATTENTION! If you choose track navigation or A-B navigation, this option will not be visible by default.
- Upcoming street: See the upcoming street name.
- Lane instructions: See which lane is the best to take, for example at an exit. Here you can choose between a simple view or a detailed view.
- Traffic camera alerts: See a warning in the image if there is a known speed camera.
- Speed information: See the speed information on the screen, both how fast you drive yourself and how fast you are allowed here.
- Show next waypoint information: Choose here if you want to see information for the upcoming waypoint. Also, make a distinction whether you only want to see the information of viapoints or of all waypoints.
- Show original route: Choose here whether or not you want to continue to see the original route regardless of how you drive.
- Show tracklog: If you are tracking, choose here whether or not you want to see the track line.
Map layer
In addition to the instructions, it is also important to visually get the navigation as much as possible to your liking. Therefore, choose what the appearance of the map and position indicator should look like in these settings.
- Map style: Click here to open the map style settings.
Position indicator colour: Adjust the color of the position indicator here so that it is most visible to you.
Position indicator circle: Choose here whether or not you want a circle around the position indicator.
Zoom adjustments: With this setting it is possible to automatically zoom in and out based on your driving behavior. You can turn this option off or based on only your speed, only the driving instructions or a combination of both.
Default zoom correction: Here you can indicate whether the map should be zoomed in by default or zoomed out further.
Tilt correction: Determine here whether you want to see more or less horizon while navigating.
Opacity of lines: Determine how visible the route line is while navigating.
Width of lines: Determines how thick the route line is while navigating.
POI size: Adjust the size of the POI icons here.
Position indicator size: Adjust the size of the position indicator here.
- Map theme: Choose between a light or dark look for the map.
- ATTENTION! This is separate from the theme of the app itself. If you choose ‘Phone theme’ here, the app will take into account, for example, sunrise and sunset, but also when entering a tunnel.
- Colour scheme: Choose from one of the three color schemes.
- Edition: Select here which type of map you want to see while navigating.
- Building view: Choose here whether or not you would like to see buildings on the map. If you do want to see buildings, you can also choose whether these buildings are shown in 2D or 3D.
- Elevation difference: Choose here whether or not you want to see height difference on the map while navigating.
- Vehicle restrictions: On the map you can permanently see the restrictions of the specific vehicle. Indicate here which vehicle restrictions you want to see or whether you would rather not see them on the map.
Apple CarPlay
It is also possible to show the navigation via Apple CarPlay. If your phone is connected to CarPlay, MyRoute-app will appear in the list of possible apps.
- Click here to quickly open the last edited route.
- Click here to open the menu with search options. It is also possible to search and add a stop during active navigation.
- Click here to open the settings. This can be done both from the home screen and while navigating.
- See the various search options here to quickly navigate to your location.
- If you want to navigate to a specific address, click here to enter it.
Settings
- Voice prompts: Select here whether or not you want voice instructions.
- Audio warnings: Select here whether or not you want to receive audio alerts.
- Map style: Switch here between the normal view and the satellite view.
- Day/Night: Switch between the day or night appearance here. If you adjust this choice, it will remain selected by default.
Start CarPlay navigation
- Avoid settings: Click here to adjust the avoid options.
- More routes: Click here to choose an alternative route. ATTENTION! If there are no (good) alternatives, this button will not be shown.
- Start: Once you have found and clicked on the correct address, click on start to start navigation.
- Avoidance options: It is currently possible to avoid highways, toll roads, and ferries with CarPlay.
- Back: Click here to return to the navigation home screen.
CarPlay navigation screen
- Navigation instructions: Here you can see the navigation instructions you enabled in the settings.
- Information: See here what your arrival time is and how long and how far it still takes.
- Permitted speed: See the permitted speed here.
- Current speed: See your current speed here.
- Show entire route: Click here to view the route in its entirety on the map. Click again to return to the follow mode.
- Skip waypoint: Click here to skip the upcoming waypoint. ATTENTION! This button is only visible on routes that contain waypoints.
- Show view Options: Click here to show the zoom and move buttons.
- Visual alerts: If you have enabled 'Visual alerts' in the settings, they will be shown here.
- Zoom: Click here to zoom in and out.
- Arrows: Click here to move around the map Click ‘Done’ to return to follow mode.
- Close view Options: Click here again to close the zoom and move buttons.
Android Auto
It is also possible to show the navigation via Android Auto. If your phone is connected to the Android Auto, MyRoute-app will appear in the list of possible apps.
Settings
Start Android Auto navigation
- More routes: Click here to choose an alternative route. ATTENTION! If there are no (good) alternatives, only the route found will be shown.
- Avoidance options: It is currently possible to avoid highways, toll roads, and ferries with Android Auto.
Android Auto navigation screen
- Upcoming instruction: See the next instruction here.
- Notification: See here when there is a notification about a speed camera or average speed check. Click on Close to remove this message and see the information again.
- Settings: Click here to adjust the settings while navigating.
- Search: Click here to go to the search screen and add a stopover if necessary.
- Exit: Click here to stop navigation and return to the Android Auto home screen.
- Show entire route: When you tap the screen, this button will appear. Click here to see the route in its entirety on the map. Click on this button again to return to the follow mode.
- Skip waypoint: When you tap the screen, this button appears. Click here to skip the upcoming waypoint. ATTENTION! This button is only visible on routes that contain waypoints.
- Lane instructions: See here which lane you should keep.
- Information: See here what your arrival time is and how long and far it still takes.
Click here and open a previous manual of the app
2. App - Basics
