MANUAL 5 OF 7
The app lets you track all your trips so you can enjoy them again later. Read this fifth guide to learn how to track and add photos to your tracklog.
Tracking
Click the track button to start tracking. The button will change from red to green, and "Recording" will appear in green at the top of the screen. This will always tell you whether you're tracking or not. When you pause the tracklog, the button will turn orange and the text at the top will change to orange, indicating "Paused."
Click the button again to display the various track options. ATTENTION! For the explanation in this manual, the image has been adjusted to show all buttons. In the app, you can swipe to reveal the delete and edit options.
  1. Delete: Click here to delete the tracklog. ATTENTION! This is permanent;
  2. Pause: Pause/restart your tracklog here;
  3. Save: Click here to save the tracklog;
  4. Take a photo: Click here to take a photo and add it to your tracklog;
  5. Add a photo: Add a photo to your tracklog from your own photo gallery;
  6. View photos: If you've added photos to your tracklog, click here to view them;
  7. Travel mode: Change in which travel mode this tracklog is being tracked.
If you accidentally close the app while tracking, don't worry. You'll be asked if you want to discard the tracklog or resume it. Click Resume to pick up where you left off.
Adding Photos to the Tracklog
Permissions
When taking and adding photos to your track log, you'll receive two notifications asking for permission the first time:
  1. Camera access: Required to take photos;
  2. Photo library access: Required to add photos from your gallery to the track log and to add photos you take in the app directly to your gallery.
Camera
  1. Back: Close the camera;
  2. Flash: Choose whether the flash should be on, off, or automatic;
  3. Aspect Ratio: Choose the aspect ratio of your photo;
  4. Zoom: Choose the camera zoom level. Zoom options vary by phone;
  5. Rotate Camera: Switch between the front and rear cameras with this button;
  6. Take Photo: Click here to take the photo;
  7. Open Gallery: If you've taken a nice photo for the track outside the app, click here to add it;
  8. Retake: Click here to retake the photo;
  9. Add: If you're happy with the photo you've taken, click here to add it.
Edit an added photo
Under 'View photos' you can find all added photos. Click on them to view and edit them. Click the trash can to remove them directly from the list.
  1. Thumbnail: Here you'll see the added photo as a thumbnail; click on it to view it.
  2. Name: Give your photo a name if desired.
  3. Description: Give your photo a description if desired.
  4. Save: Click here to edit your changes.
  5. View photo: You can also click here to view the photo.
  6. Delete: Click here to delete the photo.
1. App - Getting started
2. App - Basics
3. App - Account
4. App - Routes & Tracklogs
6. App - Routeplanner
7. App - Navigation
