MANUAL 6 OF 7
Quickly create or adjust a route with the in-app Routeplanner. Read this sixth guide to learn exactly what you can do with the Routeplanner in the app.
Open in-app Routeplanner
You can open the routeplanner from various places in the app.
- Menu: If you want to create a new route, you can open the Routeplanner from the menu. You start with an empty routeplanner and can immediately start planning.
- Route screen: If you want to adjust a route, you can open the Routeplanner from the route screen (see App - Routes & Tracklogs. This is possible with both your own routes and (copies of) routes from friends.
- RouteXpert route: If you open a nice route from our RouteXperts, you can also adjust it to your wishes. Open the route and click on the pencil at the bottom left to open the Routeplanner.
- Imported routes: You can also quickly adjust routes that you receive from others to your wishes before departure.
Home screen
- Distance and duration: Here you can see the distance and duration of the route. If you are starting a new route and have not added any waypoints yet, you will not see anything here;
- Show route: Click here to show the entire route on the screen;
- Current location: Click here to show your current location on the map;
- Yellow button: If you click here, you can add a new waypoint.
Menu
- Search: Search for an address;
- Save: Save the changes;
- Delete: Click here to discard the changes. If you edited an existing route, it will be returned to its original state;
- Close: Close the Routeplanner;
- Route information: Adjust the privacy and travel mode of the route here. Give the route a (different) name and, if desired, a description;
- Route options: Select the route optimization and which roads are allowed when planning the route;
- Waypoints: Open the list of waypoints here;
- Reverse route: Reverse the route in one go. This option is only visible for existing routes;
- Copy route: Make a copy of the route so you always keep the original route. This option is only visible for existing routes;
- Lock Route: If you only want to check the route and avoid accidentally clicking buttons, lock the route. Click here again to unlock the route;
- Navigate: Start navigation directly from the Routeplanner when you have opened an existing route;
- Delete route: If you're working on an existing route, you can also delete it in the menu. If you do this, it will be moved to the trash and permanently deleted after 30 days;
- Use offline maps: Click here to work offline. Click again to go online;
- Manage offline maps: To work offline, you must have downloaded the correct regions, just like with navigation. Click here to go to the correct location in the app;
- Map style: Choose the map style you want to use in the Routeplanner here.
Add a waypoint
In this section of the explanation, several buttons are always the same. For clarity, these are the buttons, their functions:
- This yellow button has multiple functions. It allows you to add a new waypoint and serves as a confirmation button.
- The green check mark is the confirmation button. It allows you to permanently place floating waypoints on the map.
- The red cross is the cancel button. It allows you to cancel the current action.
You can add a waypoint to the route in several ways:
- Press the map: This option is useful when you know exactly where you want to place a waypoint on the map. Press and hold this location, and a floating waypoint will appear. Confirm or cancel the action.
- Find address: Select this option if you want to place the waypoint at a specific address. Don't forget to confirm or cancel your choice with this option as well.
- Yellow button: Click here to add a new waypoint and confirm or cancel this choice.
Add and move waypoint
Sometimes you want to add or move a waypoint in an existing route. This is of course also possible in the in-app Routeplanner.
- Short press on the route line: If you short press on the line, you can add a waypoint between existing waypoints and it will be placed exactly on the route line. Don't forget to add the floating intermediate point permanently by clicking on Add or the yellow button.
- Long press on the route line: If you press on the line longer, the intermediate waypoint will be placed directly and exactly on the route line. However, if you move this intermediate waypoint, you can move it directly to a new location.
- List of waypoints: You can also quickly move an existing waypoint from the list of waypoints. Drag the waypoint to be moved to the correct location by pressing the dots on the left and keep it pressed while you drag.
Waypoint menu
Click on a waypoint to display additional information. This can be done from the map or from the waypoint list. All these options are optional.
- Waypoint: Just like on the map, you can see which waypoint you've selected;
- Move: Click here to move a waypoint. Don't forget to click the yellow button to finalize the change. You can also move a waypoint from the waypoint list or by long-pressing and dragging the waypoint on the map;
- Type: Change the waypoint type here. You can choose between a formation point (the droplet icon) and a via point (the hand icon). ATTENTION! You cannot change the type of a start or end point;
- Icon: Add an icon to the waypoint to see at a glance what to do there;
- Delete: Click here to delete the selected waypoint;
- Color: Give the waypoint a different color here;
- Name: Give your waypoint a name. This name will be spoken when you have enabled waypoint notifications (navigation settings - audio);
- Pause: Add a pause to this waypoint. ATTENTION! Navigation will not use this pause. It is only for route planning;
- Note: Add a note to your waypoint. This note will be spoken when you have enabled waypoint notifications (navigation settings - audio);
- Offroad: Click here to set whether or not this waypoint is offroad.
2. App - Basics
